y7 y8 mini me getting code 13
Old Aug 31, 2025 | 12:00 PM
hondamandawgfis's Avatar
Icon7 y7 y8 mini me getting code 13
y7 block y8 head how the **** to fix code 13 i replaced the piglet cus it was staring to tear and you could see the copper fixed it and still getting the code should i check the purge box or what, i have other codes like
22 41 im tryna fix this code 13 an go down the list but i have a chipped p28 and before i did the head swap i didnt have any codes i used basically everthing from my y7
Old Aug 31, 2025 | 09:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: y7 y8 mini me getting code 13
The Baro sensor is found INSIDE the ECU... so fixing that code requires swapping in a known good ECU. If your ECU is programmable, you could disable the Baro sensor to kill the code, but this will eliminate your atmospheric correction at start up.
My JDM EJ8
Jul 20, 2009 07:01 PM
SlowSOHC-T
May 15, 2008 06:34 AM
kamakaze1
Jan 31, 2007 04:52 AM
Ser1N
12
May 25, 2006 09:15 PM
