civic 2000 mb2 d14z4 fastback UK made rear trailing arm bushings
Honda gives 52370-st3-g10 and 52371-st3-g10 for the whole arm assembly and no separate OEM code for the bushings. Did some research and codes like 52385-st3-g01 / 52385-sr3-000 pop up as beeing compatible bushings. Can anyone confirm this?
I've never found OEM trailing arm bushings sold separately in the US but if you come up with them let me know cuz it's time for new ones again.
https://a.co/d/0QLDMez
The reasons I've avoided PU is the rougher ride and I've heard they will take a set and you have to periodically lube the pin. If you're racing those things aren't a factor but for my reliable daily driver not worth it.
hialeahzbg
Jan 3, 2007 08:56 AM
