CEL Help 98 Civic Hatchback DX
Looking for some smog help. Live in CA so already know having cars in CA sucks. No i’m not moving. Previous owner half assed the swap and my kid was dumb and bought it and can’t go back in time and not buy it so need to fix it and get it smogged and on the road . So here’s the dilemma, it’s throwing a P0505 for Idle Air Control System. So seems like probably need a new IACv, problem is which do i need, the 2 wire or 3 wire IACV or what should i look into changing?
Car itself is a 98 Hatchback that was originally auto thats been manual swapped. It currently has an auto y8 motor but has a y7 intake manifold. The ECU i believe is from a manual ‘99 EX with code 37820-P2P-A12. are there any difference in the IAVC’s besides being 2 vs 3 wire? which should i get? should i, or do i need to swap the intake manifold also and find a y8 manifold for a manual?
thanks in advanced.
thanks in advanced.
for smog purposes everything would need to match to 99 though. car has to be smogged as a 99 due to the year of the motor. so i’m guess would have to convert from obd2a to obd2b or whatever 99’s are?
If you can share the specifics of the law you need to meet to pass then maybe the collective knowledge here can get you the answers you're looking for.
The specifics of the law are its a direct replacement engine. The chassis is a 98, all parts used should be from 96-98 obd2a but he doesnt want to listen.
JHP
Sep 7, 2010 06:12 PM
blackbmagic
Sep 29, 2009 11:02 AM
polything
Sep 2, 2008 04:51 PM
