Trustworthy Aftermarket Parts Manufacturer?
Old Aug 20, 2025 | 04:15 PM
PineSmellsNice's Avatar
Default Trustworthy Aftermarket Parts Manufacturer?
Hello! I'm currently contemplating the replacement of the IACV on my v6 honda accord. However, the prices of an OEM replacement part can range from $300 to $350. That's quite pricey so I was wondering if you guys knew of any trustworthy aftermarket parts manufacturer for this particular part. The part number for my IACV is the following: 16022-P8A-A03
Thanks for any input you provide.
Old Aug 20, 2025 | 11:35 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Trustworthy Aftermarket Parts Manufacturer?
Assuming you mean a 3.0 V6 from 98-02...
$300 sounds about right from Honda.
Aftermarket.
~$150 from a local auto parts store
~$60 from Rockauto.com
Wells, Standard, or Beck/Arnley will be fine.
Before changing the iacv out, verify it is not something simple that is causing your idle issues.
A clogged screen on the O-ring gasket, or coking of the throttle blades may cause idle/return to idle issues.
Do not spray into the IAC as that will kill it.
Remove the screen if it is cooked up.
Manually clean the throttle body throat and butterfly with a clean rag/shop towel soaked in TB cleaner, wipe down the butterfly edges
Old Sep 29, 2025 | 06:44 PM
01_F23A1's Avatar
Mike is right and AutoZone's Duralast brand is made by wells, with a lifetime warranty. Put one on my 01 4 cyl about a year ago no issues.
850R
Oct 16, 2018 10:56 AM
gavoci92
Honda Accord 2018- Current
Apr 30, 2018 10:20 AM
scanlessfool
Oct 20, 2009 08:24 PM
Delano5050
Jan 8, 2007 05:06 PM
Daftboy
Oct 4, 2004 03:13 PM
