2005 Odyssey right front turn signal ground.
On a 2005 Odyssey the right front turn signal ground wire goes to a bolt on the frame down below it. Four other grounding wires seem to ground to that bolt as well. Can anyone tell me where the other 4 wires are from? Having a continuity issue with the turn signal and want to make sure the others are good as well. Thanks in advance!
crazybeanery0
Sep 15, 2008 08:55 PM
Is grounding the only cause for whining noise when reving? (since it's been brought up so much and t
2000Accord5sp
Audio / Security / Video
Feb 12, 2003 11:11 AM
