alignment off a bit, question
Old Aug 6, 2025 | 11:40 AM
GilLesS72's Avatar
Default alignment off a bit, question
Hi guys!alignment been done on my 2014 honda pilot 4wd, posted the report (it's in french sorry, located in north america). front driver side seems out of spec, I was wondering where to look as I am thinking worn out component...Note that I AM RUNNING BIGGER TIRES 265-70r17 so idk it might be harder to align?Many suspensions component been changed.On the front end - both inner and outter tie rods (TOR), both swaybar links (MOOG :/ wanted links with zerks) and both swaybar bushings (MOOG), both lower control arms (from Auto-shack).The struts are what I plan to do next (top plate bearings are suspicious and due tbh as they never been done)Rear end i only did both swaybar links (Metrix) and both lower foward control arm (TOR).looking for pointers or someone who experience similar caster problem on the front end.Thank you! i can provide more info on demand
Rob.
18
May 9, 2014 07:30 PM
NayborhoodJohnny
Nov 4, 2009 04:01 PM
litterbox
Suspension & Brakes
Oct 21, 2005 09:15 AM
Ajax
May 24, 2004 10:58 AM
rjr162
Jul 7, 2003 08:56 PM
