Solenoid wiring
Old Jul 31, 2025 | 03:11 PM
Brookeallyn's Avatar
Default Solenoid wiring
Hey there so I'm taking the motor and tranny out of my 2000 Honda Accord and putting it in a 96 Honda Accord.im leaving the wiring harness that the 96 has in it now just like it is but the 96 only have 4 plug shifting solenoid system and the 2000 has a 6 plug shifting solenoid system . So I need to know how to rewire the 4 plug wiring harness into a 6 plug solenoid harness
Old Jul 31, 2025 | 05:42 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Solenoid wiring
Looks like a deletion?
To answer your question, you cannot use the M6HA with the H4A harness/tcu.
If you're going to use the F23 in a CD Accord the easiest would be to put the F23 in the Accord with the existing harness and H4A trans.
If you are looking for better acceleration with an AT and F22/F23, use the Ody H4A 'MPJA' transmission.
IMO you will get better performance from swapping to the Ody AT than with switching from a F22 to F23.
GrimLude
May 13, 2014 11:24 AM
Project_SOHC_EX
Jul 4, 2006 04:57 PM
