Rocker shaft o-rings/Spark plug tubes
Old Jul 17, 2025 | 06:31 PM
PSherm's Avatar
Default Rocker shaft o-rings/Spark plug tubes
91 Si 1.6l, trying to find a part number or kit that has the lower spark plug tube o-rings that go under the rocker shaft assembly. Looking at kits for valve cover gaskets appear to have the upper spark plug tube seals, but not the lowers. Looking at the videos for replacement the uppers and lowers appear different. Am I missing something?
Any help is greatly appreciated and my spark plugs will also appreciate it...
TIA!
Old Jul 18, 2025 | 03:26 AM
hondamark35's Avatar
Default Re: Rocker shaft o-rings/Spark plug tubes
the plug tube o-rings are more often part of cylinder head gasket kits. cheapest on Rockauto right now is only $25, still worth it even if you toss the head gasket (which I wouldn't put much trust in at that price...)
you can get them a la carte from Honda: 3 of 91301-PJ7-000 and one 91302-PJ7-003.
Old Jul 18, 2025 | 05:42 PM
PSherm's Avatar
Thank you very much for the part numbers!!
CONTROLLED CONFUSION
Nov 8, 2007 03:23 PM
2oh6civic
Dec 28, 2006 01:49 PM
ek9child
Jun 3, 2006 12:09 PM
