Cylinder #3 not firing
Old Jul 12, 2025 | 11:56 AM
Syndeko's Avatar
Default Cylinder #3 not firing
Cylinder #3 on my d15b7 isnt firing. It has spark and the distributor is good, the fuel injectors are getting power but I noticed that Injector #1 and #3 are cracked where the spray nozzle is.
Im ordering new ones but Im wondering if the crack could have caused this altogether
Old Jul 12, 2025 | 07:15 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Cylinder #3 not firing
If you know that you have spark at the plug in cylinder #3, you need fuel and compression to make it work. Move the #3 fuel injector to another position on the fuel rail: IF the problem moves with it to the new position, then you know that the fuel injector is the problem. If the mis-fire stays in cylinder #3 after moving the fuel injector, then do a compression test on the #3 cylinder.
Old Jul 13, 2025 | 12:35 AM
youstolemybeer's Avatar
5 Year Member
not to argue, but I would do the compression test before swapping injectors. Pulling a plug is a lot easier than pulling the fuel rail. Dumb question, you said you had spark on 3. Did you see the spark at the plug? or did you use a sparkplug tester between the plug and the wire. Ive seen spark at the end of the wire and still no spark at the plug due to a bad spark plug
EAST10DECALS
Acura TL, RL & ZDX
Jun 8, 2017 07:06 PM
mouab18c1
Oct 1, 2012 08:40 AM
BoostR41
Engine Management and Tuning
Jul 18, 2009 06:28 PM
playAho
Aug 16, 2004 12:11 AM
SEFIxCivic
May 14, 2003 07:58 AM
