coolant circuit overflowing above 600mbar
Old Jul 6, 2025 | 01:26 AM
Nusmi's Avatar
Default coolant circuit overflowing above 600mbar
Hi,
d16y8 boosted / arp struts/ SF rods / carrilo pistons,
Is it possible after 1000km of engine running-in that a pressure of 600mbar causes a pressure leak in the cooling circuit? ( cometic gasket )
I have coolant splashing in the engine bay afterwards. And after refilling the coolant, the engine works perfectly under 600mbar
gasket dead ?
Old Jul 6, 2025 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: coolant circuit overflowing above 600mbar
Re-torque the head studs... you may have already damaged the head gasket, but you might get lucky. Since it is easy to do on a SOHC engine, it is worth a try.
Old Jul 7, 2025 | 02:19 AM
Nusmi's Avatar
thank's for reply ,
I think I found another probable cause of the problem,
when I assembled the engine I thought that this trace of corrosion was not important, the error is perhaps there
Hacim1906
Apr 20, 2023 08:24 PM
JEM1IRL
May 13, 2017 08:23 AM
daboy155
Aug 3, 2016 07:41 AM
2000_IntegraGS
Aug 8, 2010 03:46 PM
DennisWaller
Aug 6, 2008 02:33 PM
