96' D16Y7 DX setting ignition timing
Old Jun 21, 2025 | 08:25 AM
Calatt95's Avatar
Default 96' D16Y7 DX setting ignition timing
Hey All,
I replaced the distributor recently on my 96' Honda Civic DX, I went to set ignition timing, I jumped the blue connector with the black and brown wire that was in the green connector holder along the right side of the passenger footwell, when I do this and start the car, the SRS light is steady on, is this something I should be worried about or is it normal for it to come on when doing this?
Old Jun 21, 2025 | 08:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 96' D16Y7 DX setting ignition timing
It is normal for the "Check Engine" and the "SRS" lights to illuminate when you short the service connector... and if neither system is storing any codes, these two warning indicators will stay on solid until you remove the jumper from the service connector.
Ahale2196
Jan 10, 2017 06:23 PM
joshd_bh
Oct 16, 2012 10:41 AM
sohcrx91331
Jul 12, 2009 01:48 PM
CBR
Sep 18, 2004 06:21 PM
tygsr
Mar 9, 2002 09:48 PM
