Honda CR-V & Element 2WD & 4WD Element & CR-V
Power steering sensor problem after changing coolant
Old Jun 14, 2025 | 07:35 AM
dtrummor's Avatar
Default Power steering sensor problem after changing coolant
Had my CR-V 2014 on service, they just replaced the coolant.
When I got it back the steering seemed odd.
The steering wheel won't go back as easily. Seems more affected when I turn right.
I suspect a power steering sensor is about to go.
Can this be caused somehow by the service or is that impossible?
Any thought on if it can be the power steering sensor or the pump?
No warning lights on the panel shows.
Old Jun 15, 2025 | 05:10 PM
pscarbor's Avatar
Default Re: Power steering sensor problem after changing coolant
No telling what happens a lot of times when you turn your car over to a mechanic. This is the main reason that I do all my own maintenance.
Gman2010
Honda Civic (2006 - 2015)
Sep 5, 2021 10:41 AM
TrzystaCek
Jun 18, 2018 01:54 PM
ajmitch51
May 5, 2014 05:58 AM
Bradsxx7
Apr 12, 2009 02:36 PM
noble4ws
Nov 5, 2003 08:33 AM
