Kit car using Accord as donor
aww i remember that. at that time it came out i was 12.. and i remember brandon was 11 and rest of the honda crew was from 12-14
no, seriously though, i want one.
this could be old, but i think i got an erection!! sounds awesomely cool and you could build a supercar for less than 30K, and it would be REALLY fast, imagine a 300 WHP 800Kg car? IT'S A MONSTER!!
The last time someone posted this it got deleted, I see a similar fate for this post. personally I like the thing, I wouldn't spend like $16K to have them build it for me though
Elgorey's post shall not be deleted, he is from the Competition forum and doesn't travel these waters
the car is basically audi parts with honda Accord base and base H22 motor
Nick do delete this though if it becomes a I fruck that girl" or "it would be bad *** with turbo H22 in it " million times repeated post
[Modified by urbanlegend21, 11:16 AM 11/20/2002]
Why dont you post up some specs of it?
Length 4040mm (159in)
Width 1860mm (73.2in)
Width/Mirrors 1980mm (77.9in)
Height 1055mm (41.5in)
Wheel Base 2440mm (96in)
Weight cca 850kg (1870lbs)
Base Prices:
Kit Price: $16,600
Kit includes everything you need to build your Attack as seen on pictures, except aftermarket steering wheel, shifter, exhaust tips, wheels, additional gauges and carbon fiber “front lips”. Waterproof interior seats and panels are included.
Turn-key Price: $33,900
(includes donor car)
Roof Top Set: $2,900
Includes professional convertible 3M soft top roof (three layers: waterproof, temperature/noise isolation, temper proof), aluminium/fiberglass construction with latches and fasteners, rear wall with rearview window, detachable polycarbonate side windows, set of weather sealing, tension linkage.
Carbon Fiber Interior Set: $2,600
Carbon Fiber Front Lips: $370
HID Xenon Light Unit: $460
Edit: It also states that the Attacks tubular chassis surpassed even NASCAR.
[Modified by TouringAccord, 11:19 AM 11/20/2002]
Here's some more.
Engine Dimensions:
Length: 76 cm = 30 inch
Width: 77 cm = 30,5 inch
Height: 58 cm = 23 inch
The Attack also has an optional All Wheel Steer that you can turn on and off for better parking ability. This is due to the fact that the Accord front suspension and engine are mounted in the rear of the Attack.
The pedals and drivers seat are both adjustable to accommodate just about any size person.
Engine Dimensions:
OUCH!! LMAO!
