Crank/no start after dizzy replacement
Old Jun 6, 2025 | 07:06 PM
DillPickle478's Avatar
Default Crank/no start after dizzy replacement
Hello everyone. Im seeing if any of y'all can help give guidance with an issue im having. On my 91 sedan (LX auto) im having an issue. Im getting a ecu code 8 (TDC sensor) after replacing my distributor. I replaced it because I was already getting a code 8, and I have a crank/no start and its still showing code 8. Is there any way I can test wiring and verify that its good harness side before I just keep throwing distributors at it? Thanks.
Old Jun 8, 2025 | 02:49 PM
perfecteg's Avatar
Default Re: Crank/no start after dizzy replacement
Check the wiring for the small plug on the distributor
Old Jun 8, 2025 | 04:22 PM
I did see a wire that was exposed slightly but its not visibly broken.
scottso990
10
Aug 2, 2010 12:54 PM
Gaspari
Engine Management and Tuning
Jul 5, 2010 09:48 PM
sloweh3
Oct 21, 2003 08:17 PM
CrxSaint
Sep 23, 2002 06:53 PM
Spade
Jul 30, 2002 02:05 PM
