Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Will an 03 Ex ecu work in an 03 LX??
Old May 26, 2025 | 07:27 PM
Bugeye_rees's Avatar
Default Will an 03 Ex ecu work in an 03 LX??
Hi so I engine swapped my automatic 03 lx and put in the d17a2 with the vtec. Also threw in the jdm 3 speed with overdrive automatic transmission. Car drives fine but the gas mileage is pretty bad I’m getting 8-13 mpg. I have no exhaust leaks or vacuum leaks. I don’t know how to fix that issue. The code I’m getting for my check engine light is “torque converter circuit open” but I replaced all the shift solenoids and it’s still there after erasing. I’ve been daily driving this car for almost a year with this issue and my only problem is my mpg. Someone said put an ex ecu in but I wanted to know will it be plug and play for what I have? I don’t have the wire for the vtec solenoid and egr so would I need an ecu and seperate ex harness?
Old May 26, 2025 | 09:41 PM
Chrisfrom1986's Avatar
Default Re: Will an 03 Ex ecu work in an 03 LX??
The engine, transmission and ecu must all match in an automatic chassis. You cannot mix any of the 3.
Natem254
Mar 28, 2022 09:38 AM
Pogusone
Aug 26, 2021 03:53 AM
Tim Hitzeman
Dec 8, 2019 11:39 AM
Metalzone
16
Aug 3, 2015 12:04 PM
Quad-Damag
10
Jul 13, 2003 03:52 PM
