D series PS pumps on B16/B20 engine
I'm building a B16 head B20 block motor for my EK, I'm not sure if there's a way I can retain my current D-series PS pump. And will it fit with my current EK OBD2a PS lines.
So a B16 upper bracket, B20 lower bracket, and a D16 pump combination.
I've read somewhere that a D-series pump bolts to a B20 motor but I haven't seen anywhere if it would work with a B16 upper bracket. Thanks!
It simply doesn't work with a VTEC DOHC head. The "D" series P/S pump WILL work on a non-VTEC "B" series engine as long as you utilize the CR-V bracket. The difference is that the "B" series P/S pump has the two mounting ears in the same plane vertically whereas, the "D" series pump mounting ears are out of phase and align in two different planes.
