d17a2 crank no start
im stuck in a crank no start situation ive changed the belt,water pump, tensioner, secondary igniton, fuel injectors, starter, battery, egr, ect sensor, thermostat, head gasket, studs and valves made sure they were adjusted my timing is all good the timing belt has a little play but you would still think it would at least misfire but i need sum help the green light comes on when i turn the key my check engine light will also go off after cranking it over i have good fuel pressure too and my compression and spark is good timing is good as well just that little bit of play could anyone help?
Blackhalo6
Honda Civic (2001 - 2005)
Jan 2, 2014 12:17 PM
