Ls ring gear swap
Recently blew the diff and broke the case on my gsr trans, picked up a complete ls trans for cheap. Plan on putting the gsr gears in the ls case but don’t want to use the 64 tooth ring gear. I’ve heard the gsr 66 tooth ring gear won’t work as the bolt pattern is different. Is there any other options for 66 tooth gears that will bolt to an ls diff?
Hondaciv90
Apr 14, 2025 06:45 AM
scspeed
Transmission & Drivetrain
Feb 2, 2010 09:19 PM
