Ep3 trans into Rsx type s
Old Apr 10, 2025 | 02:07 PM
Lunajbrandon96's Avatar
Default Ep3 trans into Rsx type s
eed help on figuring out how to make my speedo work using ep3 transmission. I have a k24 engine and 5 speed trans from 02 civic si, also using kprov3. My vtec doesn’t engage and speedo doesn’t work. I have read that I might need to re pin the plug on the harness and shave down the speed sensor to make fit. Honestly if I can just get vtec to work I’ll be happy.
Any help would be greatly appreciated!!!
Old Apr 10, 2025 | 08:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Ep3 trans into Rsx type s
What year is your Type S chassis ?
Old Apr 11, 2025 | 04:02 PM
i have an 03 rsx type s
Old Apr 11, 2025 | 08:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the chassis is a 2003 model and the replacement transmission is from an EP3... the VSS should work. Make sure the 3-wire VSS plug is fully connected/plugged in and the VSS is properly inserted into the transmission. If all this seems correct... maybe the VSS is bad. If you had a previous transmission that the VSS worked in, swap the sensor to your new transmission. If you are unsure about whether the VSS actually worked before... check the VSS fuse as well.
Old Apr 12, 2025 | 08:14 AM
Thanks for your response, I recently bought the vehicle with little information I just checked back and now I’m not sure if this an ep3 transmission as the speed sensor is located in the front of trans, I took out the sensor and it for sure doesn’t fit into plug, it needs to be shaved down a bit
Old Apr 12, 2025 | 08:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Don't plug it in... you can damage your ECU or other electronics. That type of sensor doesn't work with your chassis directly. You will need to purchase a speed sensor converter and wire it in. K-Tuned makes one.
Old Apr 13, 2025 | 07:25 AM
Thanks!!! I will look into getting the converter, hopefully that solves this issue
Old Apr 13, 2025 | 02:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
When you wire in the converter, you will also have to change the plug for the VSS. Make sure you get the wires connected in the proper order from left to right.
Old Apr 13, 2025 | 09:19 PM
Sounds good I just watched a video on how to set up the converter and seems pretty straight
forward I really appreciate the information ! I got one on the way
Old Apr 14, 2025 | 09:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
You are welcome. This is what Forums like this are for.
carbonimportslude
51
Dec 29, 2024 04:20 PM
770_dc2
18
Sep 7, 2012 06:15 AM
k_powered_hatch
Honda Civic (2006 - 2015)
Mar 5, 2012 04:24 PM
HONDAPARTSMANMIKE
Jan 16, 2012 06:13 AM
ktwampdc5
Oct 20, 2008 08:01 AM
