is 2 1/2 exhaust good or should I run 3" ..................
Old Nov 19, 2002 | 12:49 PM
civicwagonman's Avatar
Default is 2 1/2 exhaust good or should I run 3" ..................
d16z6 with ihi turbo. will the 2 1/2 be fine or would I notice a difference with the 3" pipe?
Old Nov 19, 2002 | 02:09 PM
KTeller8's Avatar
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (civicwagonman)
3" will allow more flow, but it too could depend are you pushing 6 psi or 20? ya know where i am coming from?
Old Nov 19, 2002 | 08:25 PM
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (KTeller8)
i will be running around 7-10 psi when i get it tuned. I'm thinking it can't hurt to go with the 3", what do you think?
Old Nov 19, 2002 | 08:39 PM
cock head's Avatar
please get an exhaust cut out, you will not regreat it.
Old Nov 19, 2002 | 08:44 PM
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (therumblingteg)
you don't think 3" thru the muffler is enough? where would you put the cutout?
Old Nov 19, 2002 | 08:50 PM
TheSwift1's Avatar
i have yet to see some dyno charts showing the HP gains of a 3" exhaust over a 2.5" for a HOnda...how much power gain can be expected below 14psi?
Old Nov 19, 2002 | 08:57 PM
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (TheSwift1)
the main reason I'm thinking of 3" is because I want to throw something on there pretty quick, which means getting maxi muffler to bend the pipe for me, which wouldn't be madrel bends. all I need on the wagon is two 45's. maybe I should just put the 2 1/2 on. don't think two 45's would slow it down that much would it?
Old Nov 19, 2002 | 09:01 PM
CzanSOHC's Avatar
buy mandrel bends from Jegs or summit, then have them weld them in.
Old Nov 19, 2002 | 09:09 PM
cock head's Avatar
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (CzanSOHC)
2.5 is good put the cut out right in front of the catlatic converter, its way better than a 3 inch pipe. When you open that thing the turbo spools up so much faster and you can feel the turbo kick in so much sooner.
Old Nov 19, 2002 | 09:18 PM
Smashback's Avatar
I would get 3' for damn sure if you're not getting mandrels. That way you'll end up with exhaust that is the same or a little better than mandrel 2.5"
A 3" will give more power than a 2.5" but say you're only running 7 PSI, the difference might be 2 hp or something like that.
Old Nov 19, 2002 | 10:03 PM
yellowsub's Avatar
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (Hatchblack)
but its not just power gain but spool up time too.
Old Nov 19, 2002 | 10:38 PM
b_edson's Avatar
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (yellowsub)
I noticed that my turbo spooled up a lot quicker when I put my 3" exhaust on.
Old Nov 19, 2002 | 11:49 PM
KTeller8's Avatar
Default Re: is 2 1/2 exhaust good or should I run 3" .................. (b_edson)
here is the 2.5" set up i did for another HT user https://honda-tech.com/zerothread?id...376679#3376679
Old Nov 21, 2002 | 05:25 AM
do'nt necessarily need the turbo to spool quicker, i have a subaru ihi on it. comes in quick, more upper low end which is what I wanted with the awd, but its losing out above 5 or 6 due to me still running stock exhaust on it. I guess i'll notice alot with 2 1/2 or 3".
Old Nov 21, 2002 | 09:16 AM
KTeller8's Avatar
i promise you will notice a difference
roost 'er
Jul 27, 2008 08:00 AM
lude1888
Mar 16, 2007 12:11 PM
95cxhatch
Feb 20, 2005 02:34 PM
Endoe
Dec 15, 2004 09:41 PM
yimmy
May 17, 2003 06:41 PM
