Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How to repair these threads?
Old Mar 4, 2025 | 06:24 PM
010's Avatar
010
Default How to repair these threads?
I pulled the threads in the upper-right bolt hole in the block that receives the front engine mount. This hole seems unusually large for its bolt size (M10x1.25, apparently). It is as if it has been designed extra large to allow tolerance for inserting the bolt, and seems like the threads start part way into the hole by design (I can't tell, since the threads are damaged). The M10x1.25 Time-Sert bushing I have slides right into the hole, making it clear it won't work...unless, again, the bolt is designed to sit deep in the hole. I'm a bit confused by all of this.
Old Mar 4, 2025 | 07:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: How to repair these threads?
It does sit deep in the hole... the smooth area just inside the hole opening is normal. I would time-sert the hole if I were you.
Old Mar 8, 2025 | 08:16 PM
micho096's Avatar
I had same problem. Buy helicoil m12 x 1.25 kit and repair
Koko4
16
Dec 25, 2013 05:42 PM
Luckywhiteboi
Mar 6, 2009 03:58 AM
Mr.Speed
Mar 13, 2008 04:09 AM
HCivicSi23
Jul 14, 2007 11:15 PM
Silude
Jun 3, 2001 07:36 PM
