Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Crank timing gear and harmonic balancer issue
Old Mar 2, 2025 | 07:03 PM
ksack001's Avatar
Default Crank timing gear and harmonic balancer issue
So I am putting a new crank gasket, water pump and timing stuff. The timing gear and harmonic balancer had to come off with pullers, they were stuck on there like crazy. Now they won't go back on and the end of the crank isn't splined, but there's marks like it so from corrosion getting in the splines that are on the timing gear and balance, you can see in the pic. I can't reinstall the timing gear or harmonic balancer without using a damn sledge hammer. What's the best way to clean this up and get them back on?
Old Mar 2, 2025 | 07:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Crank timing gear and harmonic balancer issue
400 grit sandpaper. Be slow and deliberate.
boostedteg4dr
Feb 25, 2014 08:39 PM
Acidcrakker
Oct 30, 2007 04:23 PM
tek_civic
Jun 1, 2004 01:43 PM
