Clutch issues 98 CRV
Hey all, doing this thread hoping it will revive the subject and hopefully give me some answers, all the forums i searched have somebody having the same issue as me, but nobody posted a fix.
So my clutch started slipping like 2 months ago, took the car to a service, i was told that the clutch had to be changed, i was ok, so they ordered everything but the flywheel, few days later go the car out, same issue, for some reason these guys did not want to work on my car anymore so i went somewhere else, bought a flywheel too, that was changed, the clutch worked for a while but now the issue came back. Changed the clutch pump and the receptor or however its called, at the front of the engine, low side. I think its the slave cylinder. SO basically everything is new but still having the same issue. Clutch slipping after a while, i think when parts are wormed up, but not sure what is the triggering effect, heat or time. The problem is on and off too, yesterday i drove the car around the service, changing gears constantly trying to get the problem to come up so i can take the car straight to the service so they can look at it while the problem is on, but after one hour of driving i could not get the slip to come up. Another weird effect is that the clutch pedal is becoming really hard to press when the clutch slip comes up, usually the clutch is normal on cold start, but slowly gets harder to press until the clutch slips.
Anybody had this problem and fixed it or maybe ideas ?
Again, as a reminder, everything was changed, ok aftermarket but everything is brand new, even the master cylinder and slave one, oil too. The problem is on and off, but this means no long drives since i`m stuck for a while when the problem comes up, near home its a quick drive home, if the car can make it home that is.
