What coilovers will fit on my “89 EF7 CRX
Old Feb 15, 2025 | 01:17 PM
crxgrl's Avatar
Default What coilovers will fit on my “89 EF7 CRX
Hello,
Any advice would be appreciated on this. I am trying to find coilovers for my EF7 CRX but can only find ED8 CRX coilovers online ready to order. Will these fit on my car? And if not, what are the differences?
Or, do I use EF Civic coilovers?
Any other CRX owners out there, what coilovers did you use on your car as $5000nzd for custom built ones seems a little much.
Old Feb 16, 2025 | 02:29 PM
EFKDX91's Avatar
Default Re: What coilovers will fit on my “89 EF7 CRX
You should be able to search crx si coilovers and find plenty of options. Usually everyone runs ground control coilover sleeves on koni yellow shocks. It will run you around a $1,000 usd.
Old Feb 17, 2025 | 12:57 PM
Tyson's Avatar
EF/ED all the same.
EG/DC works too if you swap front forks to larger diameter.
What coilovers are you looking at?
Old Feb 17, 2025 | 01:05 PM
crxgrl's Avatar
Originally Posted by Tyson
EF/ED all the same.
I am looking at Teins.
https://www.speedscience.co.nz/produ...ce-z-coilovers
Just a little nervous to buy them because all the coilovers shops are suggesting that their suppliers don’t have any for an EF7, but i am thinking that may be because they are only looking under EF7 and not any other chassis codes that would fit it.
Old Feb 17, 2025 | 05:49 PM
Tyson's Avatar
Oh actually I forgot about the rear control arms.
On 88s in the US (ED) civic/CRX came with "JDM" rear control arms, box style with eyelet rear shocks. Then for unknown/unspoken reasons Honda changed the rear control arm to a cast version, so the shock is different.
However, 89-2000 civics/Integra in the rest of the world, had the same 88/JDM rear shock and lower control arm.
The rear control arm is interchangeable. No real difference.
So if you get an ED set of coilovers meant for USDM 89+ suspension, then just get some aftermarket rear control arms to match. No big deal.
Old Feb 17, 2025 | 06:16 PM
crxgrl's Avatar
I see, thank you so much Tyson. It’s super hard to get any CRX parts and aftermarket CRX parts in New Zealand where i’m from so i’m just thinking where i could get aftermarket control arms.
Do you think that EF coilovers for the same year but different body style would work? Sorry for asking so many questions. I really appreciate your advice.
Old Feb 18, 2025 | 10:17 AM
Tyson's Avatar
Doesn't matter about body style.
ANNiHiLATORS
Suspension & Brakes
Jun 21, 2012 07:20 PM
biggjerryc
Jun 17, 2008 07:14 PM
i heart honda
25
Jan 12, 2006 09:01 AM
South Bay Surfer
Aug 15, 2004 08:20 AM
