Honda CR-V & Element 2WD & 4WD Element & CR-V
Manually Engage A/C Clutch?
Old Feb 2, 2025 | 06:03 PM
Partsguy19's Avatar
Default Manually Engage A/C Clutch?
Hi All,
Is there a way to manually engage the a/c clutch 2014 CR-V? I replaced the a/c clutch and trying to get it to engage to see if it works. Are there any wires that can be jumped? It's cold here and don't know if that's why I can't get clutch to engage. Fans will kick on when I push the a/c switch but clutch won't engage. Older models had the switch on the dryer you could jump.
Thank you.
Old Feb 3, 2025 | 11:36 AM
Ryanthegreat1's Avatar
Default Re: Manually Engage A/C Clutch?
You can put a jumper at the relay for the AC clutch.
wwolf771177
Dec 17, 2013 05:44 AM
JaimmyACA
May 26, 2013 06:24 PM
all-mtr-teg
Mar 1, 2008 11:32 PM
roundworldsobig
Jan 26, 2006 09:16 AM
JimmyAtlantis
Dec 8, 2005 12:41 PM
