Crank no start
Old Jan 29, 2025 | 07:34 PM
_kk_'s Avatar
Default Crank no start
Just purchased a 1998 Honda civic coupe. It came with a d16z6 in it and is manual. It has spark confirmed, fuel confirmed. But I don’t know what to check next. The distributor is new, plugs new, wires new, the fuel pump kicks on, and the injectors spray when cranking, it has good fuel pressure. But it also has a slow/weak crank. Any tips/ help? Also the ECU is a p2p with jumper and the battery has been fully charged on a maintainer overnight off the car. I’ve tried using a different battery and still have a weak crank. Tapped on the starter a couple times too.
Old Jan 30, 2025 | 07:15 AM
hondamark35's Avatar
Default Re: Crank no start
check timing and compression.
curious about the setup: is it a Z6 short block with Y8 manifolds? Y8 oil pump (dip-stick near crank pulley)? why is there a jumper at the ECU? OBD2a to OBD2b?
Old Jan 30, 2025 | 07:23 AM
_kk_'s Avatar
it is OBD2a, the dip stick is in between the headers in the middle. I haven’t checked timing yet, nor compression. I will soon when it stops raining here.
ErikMarteen
Oct 27, 2022 02:52 PM
maxdrivesacar
Honda CR-V & Element
Sep 17, 2017 12:13 PM
eslater72
Classic Hondas
Apr 7, 2011 03:49 PM
WifesVTEC
Jan 31, 2011 04:46 PM
reese
Jul 30, 2003 02:17 PM
