99 civic dx Need help p300 301 302 303 304 1399 codes
Old Jan 29, 2025 | 05:17 PM
Lock914's Avatar
Default 99 civic dx Need help p300 301 302 303 304 1399 codes
Hey everyone I'm coming to witts end trying to get this misfire under control. About 2 months ago my car started sputtering and dieing so i stopped driving it i got and began the mission of trying to figure it out started by replacing the fuel filter first thinking it was maybe a gas issue didn't work did the fuel pump no help . So checked my iat on my intake next replaced nothing checked the codes that finally popped up they were for the 02 switched out the o2 sensors as well and nothing. Moved on to electrical changed the plugs, wires ,cap and rotor. got it to a point right now were i can drive it by babying it and a slight misfire will happen now and again if a mis happens i just feather the gas and it breaks through andkeeps going while driving if i try to pin it seems like all power is lost and just doesnt do anything . I brought it to a mechanic he was unable to figure it out only thing he suggested was the distributor itself or ecu. I'm going to be doing the distributor this weekend to see but has anyone went through anything like this any other suggestions.
Old Jan 29, 2025 | 05:25 PM
youstolemybeer's Avatar
5 Year Member
Default Re: 99 civic dx Need help p300 301 302 303 304 1399 codes
https://honda-tech.com/forums/honda-...ghlight=po1399
Old Feb 1, 2025 | 02:04 PM
Lock914's Avatar
Just an update swapped out the distributor found a used stock one and problem fixed
Integra2316
26
Dec 19, 2012 07:46 PM
flameboy54
Apr 3, 2010 10:04 AM
97ekb18b
Apr 22, 2008 07:23 PM
Taz16244
14
Mar 6, 2008 07:30 PM
CornFlake340
Aug 19, 2006 08:15 PM
