Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How to know if my head is cracked
Old Jan 25, 2025 | 07:50 AM
Bigdawg2755's Avatar
Default How to know if my head is cracked
Ive Replaced the thermostat water pump timing belt and head gasket drove it for 20 minutes doing 45 miles an hour and started overheating again bubbles in my radiator still new radiator cap
Old Jan 26, 2025 | 05:24 AM
pscarbor's Avatar
Default Re: How to know if my head is cracked
You might try pressure testing the cooling system. I have a Slant pressure tester that I've used for many tears (about thirty). I had to buy an adapter on Amazon because the radiator cap is smaller on my Civic. Once you have it hooked up, pump it up to 16 psi or thereabouts. If it doesn't hold pressure, you have a leak somewhere. If the leak is external, you'll see water coming out, but if it's the head or head gasket, you'll just see the pressure drop.
Check out your radiator. It has plastic sides glued to an aluminum core. Over time, the glue will come loose, and the radiator will leak. This may be your issue. If so, you will see water coming out once you pressure it up.
cng civic
Jun 17, 2024 06:02 PM
collinkuhn1
12
May 6, 2020 05:48 PM
Dffdixie
Sep 17, 2016 01:27 AM
D16 Minin Me
Aug 10, 2016 01:45 PM
bomber19
Aug 5, 2007 06:57 PM
