Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
poor fuel consumption
Old Jan 2, 2025 | 04:02 PM
270140273b's Avatar
Default poor fuel consumption
Hi,
I have a 2002 Honda Civic ex (non vtec). It is consuming an excessive amount of fuel, about 8MPG (in the city) even though the traffic is light
Since I have only had it for a month and it is not like the previous owner had it, I did the following:
change filters (engine, oil and cabin).
oil change,
PCV valve change
IAC valve change (idle speed was unstable)
brake check
Today I realized when removing the oxygen sensor that there is no catalytic converter inside, I know this can increase consumption but I don't think it will increase by that much.
There is no engine light on or errors (it came to light P0420 low catalyst efficiency) but I deleted it and it has not come back.
Some of my OBD2 values ​​are, at idle after driving for about 20 minutes.
ignition timing advance for cylinder #1 (varies between -2 to -7.7 degrees)
intake manifold absolute pressure 41 to 45 kPa
engine rpm = 720 rpm
calculated load value = 41%
coolant temperature 90 degrees celcius
oxygen sensor 1 (varies between 210V to 780V rapidly)
oxygen sensor 2 (varies between 0.075 to 0.465 a little slower than sensor 1)
short range fuel regulation (-0.8% to 0.8%) in driving is usually between (-2% to 4%) normally is a little more time in a positive value
long range regulator is almost all the time at -0.8
coolp51d
Mar 10, 2018 06:19 PM
bernardo1989
10
Feb 7, 2009 03:56 PM
1990crx
Apr 3, 2008 08:42 AM
sshonda2004
10
Jul 12, 2005 01:55 PM
