OBD2a to OBD1 Conversion
Old Dec 26, 2024 | 01:44 PM
zerovandez's Avatar
Default OBD2a to OBD1 Conversion
Hi guys. So Im currently using an engine harness from a 96-98 Civic EX in my 1997 Civic DX chassis for my B18C1 swap. I have bypassed CKF sensor mod and manually wired in the secondary o2. Thus far, no issues. No CEL and everything runs fine.
So Im preparing to switch over to OBD1 ECU using a conversion adapter. Would it be necessary to undo the secondary o2 wiring? Can I just leave it without experiencing issues when switch over to the OBD1 ECU?
Old Dec 26, 2024 | 07:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: OBD2a to OBD1 Conversion
Yes, you can simply leave it be. The OBD-1 ECU doesn't recognize the secondary O2 sensor.
Old Dec 26, 2024 | 08:24 PM
zerovandez's Avatar
Awesome thanks for that. I plugged everything up and she fired up without issue. I also left the CKF mod as well since the the OBD1 ECU doesnt have these pins.
cnowak
Jul 28, 2013 07:48 PM
lexrob
Feb 22, 2010 02:55 PM
dem0nk1d
Aug 8, 2007 02:17 PM
MniMeHatch89
May 24, 2007 09:10 PM
Ls On StErIoDs
Sep 12, 2005 09:04 PM
