Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Creaking clutch?
Old Dec 24, 2024 | 07:53 AM
einzelherz's Avatar
Default Creaking clutch?
My master cylinder went out a year ago (piston plate bolt popped it's cap) after only a few years of use. Replaced it (probably like 5k miles ago, I don't drive a lot). Then last month my clutch started making this noise:
https://imgur.com/a/3Rl9PmC
I thought the plastic bushing in the clutch pedal was the culprit so I replaced that and greased it with high temp urea grease first, then switched to white lithium, but still the problem persists. I can feel the sound in the pedal and the master cylinder itself.
Anyone know what this is? Are these exedy cylinders somehow just garbage? Help please!
Old Jun 1, 2025 | 11:17 AM
esliger's Avatar
Default Re: Creaking clutch?
Following: I replaced my clutch a year and a half ago in my 3.5L, 6spd MT, 2011 Honda Accord EXL Coupe. The mechanic told me their must be something wrong with the parts I bought, because it's hard to get into gear. It is difficult and had a different shop, that specializes in transmission and clutch repair tell me the clutch is bad. That's one issue. But the other issue is the creaky sound you mentioned. The same transmission and clutch specialist told me it's inside the cabin, not the master nor slave cylinder. Despite greasing, it still creaks. So annoying. Not sure how to stop it.
Jester85
Dec 10, 2024 05:11 PM
H.N.F
Transmission & Drivetrain
Oct 1, 2016 05:20 AM
Former User
49
May 23, 2016 10:40 PM
rawfish66
Oct 7, 2014 08:58 AM
b18crx
May 9, 2009 04:54 AM
