How long after painting a valve cover before you can drive the car?
I'm using VHT flameproof primer and duplicolor engine enamel with ceramic. 2 light coats, and one heavy coat (of both primer and color).
The can says its dry to the touch in an hour and can handle in 3 hours.
It doesn't say anything about starting the car and it getting hot.
How long do I have to wait before I drive it because I'm not gonna have my last coat done until 3:30pm but I really need to go somewhere around 6.
If I'm careful to install it, would it be okay or do I really need to wait for it to fully cure before driving?
Re: How long after painting a valve cover before you can drive the car?
I'm really happy with the results, and I'm gonna paint the heat shield underneath the engine tomorrow. Hopefully it doesn't start peeling.
I kind of wish I went with a blue or white color instead but red looks nice too. Do you think the shiny gloss look will last?
So, to "cure" the VC I always cure it on the engine, basically install it and drive for about 2 to 3 days and by then the smell will go away, and it will be cured. after that take a damp paper towel and wipe the VC clean and dry it off.
Ive painted multiple valve covers for race cars with regular Rust-Oleum paint. I used to stick with the vht but I tried regular spray paint, and you know what? It lasts just fine.
Degrease/clean well. I always use primer on bare metal.
I agree on the VC, but for the heat shield, I’d use the high temp stuff.
Do you thinking it looks betterment with White dipstick handle or red? I did white at first then thought red would look better, but now I'm thinking white might have been better.
Either way I'm really happy with the results. Do you think I could paint the battery and distributor?
Do you think it looks better with white dipstick handle or with red?
