1999 EX D16Y8 Rod knock or valve lash or?
Old Dec 20, 2024 | 06:40 AM
WantSomeDank's Avatar
Default 1999 EX D16Y8 Rod knock or valve lash or?
Please help I’m not sure what engine component this noise is coming from and it’s scaring me. We just swapped the engines. My buddy’s saying spun bearing but during the spark plug unplug test the noise never stops or decreases beside deceleration. Any help would be appreciated.
Old Dec 20, 2024 | 07:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1999 EX D16Y8 Rod knock or valve lash or?
First, WHY did you post this a second time ? Second, why didn't you answer my question to you ?
It doesn't sound like a rod knock, but because the idle speed is so high, you need to fix the idle FIRST and then disgnose the noise.
Old Dec 25, 2024 | 03:38 AM
Idle is fixed sir I’m sorry, I adjusted valve lash, I just did spark plug pulling well running test each cylinder and the noise,
https://youtube.com/shorts/Qd_wBnJfv7g?si=auloEU2eq9baleyJ.
File Type: mov
DanielH2016
Jul 6, 2014 01:11 AM
rovafa2002
24
Nov 18, 2013 01:35 AM
deewaynex757
12
Mar 15, 2012 01:46 PM
LS AzZkIkr
Sep 4, 2007 05:28 AM
