EG front subframe lost captured nut HELP
I've a 94 EG coupe used for HPDE track use only. I replaced all the front rubber bushings with pillow ball bearings last winter but he captured nut welded to the inside of the subframe drivers side for the front lower A-arm bolt broke loose. This piece captured nut was welded to bolts to the front subframe and accepts the bolts that hold in the front and back of the lower A-arm. What is this part called? My shop put a 1" hole in the piece be able to get a wrench on the nut, but its a bear and it keeps loosening up. My only choice buying a subframe? Thanks, Al
1994 EG coupe
Fully caged
Interior stripped
1996 JDM typeR motor/trans, stock ECU
TypeR rear suspension
GS-R front end with 11" rotors
Located northern New Jersey
1994 EG coupe
Fully caged
Interior stripped
GReatEDDY
Sep 19, 2006 06:52 PM
