Civic bottom arms
Civic bottom arms
Last year i changed the suspension on me Eg Civic hatchback, whilst doing it the suspension bush in the bottom arms nacked up on the rears. They were pretty nackerd anyway so i bought some new bottom arms.
I have just changed the car to an Eg Civic Coupe and have swapped the suspension onto that. I have had the same problem with the bolts being seized in the bushes on the rears, and so they need replacing as i had to get them burnt out.
What i want to know is, does anyone know if the bottom arms that i bought for the Hatch will fit onto the Coupe correctly?
The difference between them is the hatchbacks have a slight bend in them at one end whereas the coupe's are straight. I have compared the two and all of the bushes seem to line up the same, there is just a bend in the arms off the hatch.
Any help appreciated.
Jon
Jon
Re: Civic bottom arms (PLatsy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLatsy »</TD></TR><TR><TD CLASS="quote">Last year i changed the suspension on me Eg Civic hatchback, whilst doing it the suspension bush in the bottom arms nacked up on the rears. They were pretty nackerd anyway so i bought some new bottom arms.
Jon
1. all EG civics and 90-01 tegs are interchangable rear lca(minus the Typr R lca.)
2. Throw away the slight bend arm, that one is damaged. Use the straight one.
3. To prevent future bolt from seizing up use anti-seize .
Jon
Re: Civic bottom arms (Lord Helmet)
the arms arnt damaged, there new and both identical. It just looks like the hatch's have been given these arms with a slight bend in them and the coupes have straight ones.
Thanks for the info
Thanks for the info
ILUVTEC
07-27-2009 04:26 AM
lilpastrana
02-14-2008 09:31 PM
89efhatchcrap
08-02-2006 07:27 AM
