Ignition distributor
I have a 99 Civic EX. I'm looking for both oem distributor shaft o ring seals. One of them is found on the exterior and one is found on the interior of the shaft. Does anyone know where I can get these seals? Thank you
The inner seal is a lip seal, the outer is an O-ring
Dorman has a seal kit: 917-136
the OE numbers are 30110-PA1-732 and 30130-PC6-003. I believe these are common to most years of single cam Civics and Accords.
