Honda CR-V & Element 2WD & 4WD Element & CR-V
2005-06 Honda CR-V RBC & ZDX Throttle body?
Old Oct 17, 2024 | 12:05 PM
Elijah102120??'s Avatar
Default 2005-06 Honda CR-V RBC & ZDX Throttle body?
I have a 2006 Honda CR-V, I recently installed RBC manifold and a ZDX throttle body has anyone else ventured down this path. Currently having rpm issues and have codes? When depressing the clutch the rpms jump while rolling?
P2279 - Intake air system leak - Checked for leaks - Found no leaks
P0507 - Pending - Idle Control System RPM Higher Than Expected.
P0135 - O2 Sensor Heater Circuit B1S1
P0661 - Intake Manifold Runner Control - Eliminated!! I have to check wiring**
Old Oct 19, 2024 | 07:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2005-06 Honda CR-V RBC & ZDX Throttle body?
Put the stock parts back on... the RBC intake manifold will lose power in the mid-range (and gain absolutely nothing at peak by the way) and the throttle body will reduce air velocity below 5500 rpm... also reducing performance from idle to 5500 rpm. You have no way of tuning for these upgrades, and even if you did, you are going backwards from a performance standpoint. If you did the RBC intake for the "look"... you have to decide what is more important: Performance or Aesthetics.
jperdikis
Jan 22, 2023 01:46 PM
Que_Lude
Dec 24, 2004 02:12 PM
lilbill3554
Jan 28, 2004 07:39 PM
