Wire from battery to taillight
hey all, 1995 civic lx (4 door) I have to run a wire from thebattery to the tail light.. Is there a easier way then drill a hole in the firewall, and fish it under the plastic trim (both doors) and thru the back seat?
I know Im not the first to have to do this, so if anyone has an easier way, I would appreciate how you did it
Thanks
Thanks
Looking at the battery and you will find a round rubber grommet about the size a quarter on the firewall. Use a utility knife and cut a “+” and push wire through. You can use a metal coat hanger to help. What’s your reason to run a wire to the back ?
I am going to tow a small trailer and have to wire the trailer lights. The trailer light converter requires a hot wire
Thanks again
spaceman00
14
Apr 4, 2006 08:53 AM
