Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 Civic LX P0135 & P0141 codes that come back with seconds after cleaning them.
Old Sep 23, 2024 | 02:19 PM
Enki_Espinoza74's Avatar
Default 2003 Civic LX P0135 & P0141 codes that come back with seconds after cleaning them.
Hi all, I just joined this forum with hopes to find a solution to my car problems as well as to helping in anyway I can. I don’t know if any of you have experienced this issue that im having with my Upstream and downstream O2 sensors. I already bought replacement sensors but the trouble code keeps coming back.
Old Sep 23, 2024 | 10:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 2003 Civic LX P0135 & P0141 codes that come back with seconds after cleaning them
Your problem is the heater control circuit... which controls BOTH heaters in the primary and secondary O2 sensors. There is a fuse for them... and it may not be marked on your fuse box cover. You will need to check a service manual for a full listing of the fused circuits.
Old Sep 24, 2024 | 11:11 AM
There is an LAF fuse under the steering wheel and it checks good. The problem I’m seeing is that the ecm doesn’t send both negative pulse to the O2 heating element.
Old Sep 24, 2024 | 08:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
That is a different fuse. There is another fuse that will have power going to multiple circuits... including the primary and secondary heater circuits.
Old Sep 25, 2024 | 11:20 AM
I will look for it but I do have battery voltage on the heater circuit with the ignition key on.
gtskywalker27
Audio / Security / Video
Mar 14, 2006 05:06 PM
Falcon1012
Oct 13, 2004 12:55 PM
sicivic
Nov 28, 2003 11:05 AM
JDEM1
Feb 23, 2003 11:49 PM
