Classic Hondas All Pre-1988 Hondas.
Thermostat prefered brand help
Old Sep 17, 2024 | 05:30 PM
letank's Avatar
Default Thermostat prefered brand help
The thermostat seems to have failed in the safe mode.... cracked open... not obvious in the summer months... the cooling system is efficient... As the weather has cooled a bit, yes, coastal California, we run the heater more than the AC... it took a good 5 miles for the temp gauge to show any activity...In stop and go traffic it will run slightly above the normal 1/3, turning on the AC will lower the temp really fast!
My question : any good brand, I used the Stant, and this is the 2nd time in 4 years that the thermostat has failed in the open... of course no OEM from Honda... Last failure was in winter and I had to put a cardboard in front of the radiator to have heat inside.
Old Oct 6, 2024 | 06:05 AM
NoMOACVWs's Avatar
Default Re: Thermostat prefered brand help
Shop for this brand, & never look back: https://motorad.com/products/thermos...e-thermostats/
Old Oct 8, 2024 | 07:47 AM
letank's Avatar
Thank you
Old Nov 22, 2024 | 01:54 PM
letank's Avatar
Finally done, another stant bit the dust, and here is the pict of the stant on the left with the failed rubber seal and the new motorad on the right
Failed Stant , New motorad on right
Edit : the rubber gasket on the motorad is in the wrong position -inside out-
Old Nov 22, 2024 | 02:35 PM
NoMOACVWs's Avatar
Buy the best, & only cry once.
Gds80
Jul 21, 2024 07:10 AM
95lover
Jun 23, 2021 04:46 AM
faran
Jul 21, 2013 08:38 AM
bracono
Jan 26, 2007 06:32 PM
silverb18
15
Jul 25, 2005 03:37 PM
