Head gasket
Hello, I am replacing the head gasket in my 1998 Honda civic ex.
are there any tips or pointers anyone has for me?
what maintenance things should I do while I’m at it?
are there any preference mods I can do?
thanks
thanks
Replace your valve stem seals while you have the head out. Check our valve to see any bent by attaching them to a drill and spin it. If it wobbles, go to the junk yard and pull valves from other civics there.
Also clean your valves with scotch brite and a drill. After that, lap your valves with lapping compound using drill at low speed. You will notice a bit more power after doing these.
Or don't do any to save time and just get your head deck and put them back together and on your way.
its your engine so do as you wish, If it were mine, I would either take the head to a machine shop and have it planed flat or order a rebuilt head HONDA CYLINDER HEADS (headsonly.com)
That way I dont have to do it again.
Clean the top of the pistons with a brass wire brush,
Why do you have to replace the head gasket?
Like this
WyoKs307
Honda Civic (2001 - 2005)
Jan 15, 2023 08:33 AM
