b20b4 head on b18b1 block
Old Sep 13, 2024 | 11:51 AM
bswapben's Avatar
Default b20b4 head on b18b1 block
so i have a b18b1 with a bent valve so i’m swapping the head off the old motor a b20b4 with a matching p75 head i got it machined and i was planning on using a b20b head gasket because that’s what everyone online is saying so i just want to make sure because it doesn’t sit right with me can anyone verify?
which head gasket should i use!!!!
Old Sep 17, 2024 | 12:14 AM
Silentz's Avatar
Default Re: b20b4 head on b18b1 block
I think the rule of thumb is whichever head you're using, get the gasket for that head.
Old Sep 17, 2024 | 03:29 AM
Chrisfrom1986's Avatar
Not when the b20b4 has a larger cylinder bore than b18b1.
Old Sep 17, 2024 | 07:32 AM
spAdam's Avatar
Loved
Community Favorite
Considering that the block determines the bore, that's not a great rule of thumb.
B20B4 head = B18B1 head. Use the stock B20 headgasket.
Old Sep 19, 2024 | 08:45 PM
bswapben's Avatar
you guys are confusing me i’m doing the job this sunday so i’ll be good using the b20 gasket when it’s a b18 block and b20 head YES? NO? and any other things i should know maybe thank you!!
Old Sep 19, 2024 | 09:15 PM
That's not what you said and you should have been more clear. Use the head gasket for the block you're using.
Old Sep 20, 2024 | 06:04 PM
spAdam's Avatar
Loved
Community Favorite
Punctuation and sentences are dead.
Yes. Use the B18B/P75 gasket.
Simon Szuba
Honda CR-V & Element
May 26, 2021 11:37 AM
strike1545
May 24, 2010 10:42 AM
mehrshadvr4
Aug 3, 2009 05:06 PM
hondacivic4g
Nov 21, 2003 02:15 PM
DLB1994
Jul 3, 2002 01:48 AM
