Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D16V1 oil consumption
Old Sep 11, 2024 | 05:40 AM
Kirjekuori's Avatar
Default D16V1 oil consumption
How common problem oil consumption is with this D16V1 engine and is there known common reason that causes it?
I bought car when it had mileage: 160000km and is was already consuming 0.5l/1000km, now it has 200000km and maybe little more, 0.6-0.7l/1000km.
Have you ever heard bad PCV valve causing oil consumption and oil leaks (cylinder head cover was leaking) in this engine? Or is the problem most likely with bad valve stem seals or piston rings?
Old Sep 15, 2024 | 08:34 PM
Silentz's Avatar
Default Re: D16V1 oil consumption
Most common oil leak on the D-series engine are from the valve cover gasket, oil pan gasket and distributor o-ring. Rarer are from the camshaft seal and both front and rear crankshaft seals.
If you suspect your valve stem seals or ring land leaking, just drive at freeway speed and floor it for a few seconds. Do you see white or blue smoke coming from behind your car? Best to have another person follow and look at it you while you do this so you can focus on the road.
92BluEH-3
13
Dec 2, 2007 11:39 AM
Acura-integra_101
Nov 13, 2005 01:34 PM
creep_gunner
Sep 11, 2005 08:30 AM
98cwitr
Apr 27, 2004 01:34 PM
combustion
Feb 15, 2004 07:35 PM
