Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Headlight issue! Plz Help!
Old Sep 5, 2024 | 08:40 PM
NewHondaKid's Avatar
Default Headlight issue! Plz Help!
Hi there I just bought a 2002 civic lx sedan with 145,000 miles on it. I’m not too familiar on how to fix cars but I. wanna try. So my left headlight low beam went out 2 weeks ago but I noticed that it had turn on later on in the evening. Today I come out and find to see that only the left low beam light is off and the rest are on. I got the light replaced yesterday and it was turning on fine but not anymore. any ideas on what the issue can be? And any recommendations with what I should do to my car to make it run better? Plz help.
Old Sep 15, 2024 | 08:41 PM
Silentz's Avatar
Default Re: Headlight issue! Plz Help!
Maybe the connector to the light bulb is loose? Or the connector is corroded?
Pull the connector out and look at it and look the wiring to see if there's any exposed wire. If it's corroded, clean it the best you can and apply dielectric grease to it before putting it back in. If you see exposed wires, tape it up with electrical tape and it should be good.
ayeejohnny
Lighting
Nov 1, 2018 07:32 AM
reddysol
Sep 23, 2007 10:42 PM
rickturboteg
Sep 24, 2006 06:16 PM
PinballPrelude
Aug 18, 2006 03:21 PM
