B16A2 SOME TIMES CRANK BUT NOT START AND MIL LIGHT ACTIVATE AND FUEL PUMP DOESNT WORK
HI, EVERYBODY
I GOT A HONDA CIVIC EK 99 WITH ENGINE B16A2 ECU P28 WITH S300
SOME DAYS AGO MY CAR CRANK BUT DOESNT START, AFTER MIL LIGHT IS ON AND FUEL PUMP DOESNT WORK
AFTER TO RESET ELECTRIC SYSTEM AND OPEN SWITCH AGAIN
SOMETIMES MIL LIGT IS GONE AND FUEL PUMP STAR TO WORK
THE ENGINE CAN START IF SOMEBODY CUOLD HELPME I WILL BE GRATEFUL IM NOT SURE IF THIS ISSUE WILL BE RELATED WITH ECU
THANKS
THANKS
Bad capacitors or damaged circuit pathways in the ECU. Replacing the capacitors may fix your issue if you get to it fast enough... the longer you wait, the better chance other components are damaged and the cost to repair the ECU increases. Either have it repaired or replace it with another P28 that is socketed for your S300.
mujunyu520
Oct 19, 2022 01:00 PM
Ethanphelps
Nov 3, 2017 10:35 AM
Omega Blaze
Engine Management and Tuning
Sep 24, 2016 01:27 PM
