2000 Civic Sedan A/C oil questions
ey guys, I just replaced my entire ac system, evaporator, drier, condenser, compressor and the blower motor.
all of the parts I have received new came dry, the only exception is the Denso compressor which I bought new and since installed it in my crv and now I took it for the civic
it had oil in it but I’m not sure how much, I never thought of it actually
The question is how much oil should I put in the system, and can it be done with the machine that charges the system with r134a?
Normally you drain out the old oil and pour new oil into the intake port. Must be done before assembly and especially start-up. The compressor should have a label that says how much oil is in it (and what type). Usually Densos have Denso ND-8. You can order a can of this from rock Auto. Part number 9990101. Its usually 4 or 5 oz that the system needs. Consult your manual.
fryman
Aug 23, 2021 09:22 AM
angrysmileyface
Jul 31, 2014 04:53 PM
cqljohn
10
Aug 20, 2011 12:15 PM
Master23
Jun 23, 2009 05:32 PM
