Honda CR-V & Element 2WD & 4WD Element & CR-V
01 CRV Spark, Fuel, No Start after Timing Belt
Old Sep 2, 2024 | 06:02 AM
cncDean's Avatar
Default 01 CRV Spark, Fuel, No Start after Timing Belt
Hello,
I bought this 01 crv with about 170k miles and it had a broken timing belt.
I pulled the head off and had it milled down and rebuilt it with new valves and seals and such.
When I went to install it, the crank position sensor was mangled from the belt breaking. I bought a new one. The same as Honda used.
I put it all together and had everything perfectly lined up with pins in the cams. Rotated by hand a few times and checked for alignment. It was a perfect install.
but now when I crank it, I get no start or fire in the cylinder. It just cranks and chugs with no sign of it firing inside.
I tested for spark and fuel. I put a little starting fluid in the throttle body two different times with no sign of firing.
I’m thinking it’s a timing issue. Either with the distributor or something with the crank sensor.
I’ve tried different positions with the distributor but no luck.
Is there something that I should be doing with the crank sensor? I vaguely remember something about unplugging the connector under the glovebox for some reason.
Thank you.
Old Sep 2, 2024 | 09:51 AM
cncDean's Avatar
Default Re: 01 CRV Spark, Fuel, No Start after Timing Belt
I did a compression test and found that cylinder 2 has 0 compression. The piston is going up and down but no reading. I don’t feel any air pushing through the plug hole when I put my face near it.
Here’s the results of dry test. Cyl
4 162
3 95
2 0
1 179
Old Sep 3, 2024 | 08:28 AM
cncDean's Avatar
I guess I’m pulling the head off to see if something got stuck under it while lowering it down.
kringb
17
Jun 26, 2022 07:21 AM
Tother162
Mar 27, 2022 01:29 PM
Macnotiss
10
Oct 18, 2017 05:44 PM
CivicSmith
42
Jul 8, 2014 12:54 PM
ylwbastrd
Oct 17, 2002 10:10 PM
