Fuel pump will prime but no fuel pressure
Old Aug 27, 2024 | 01:04 PM
Mjalaly's Avatar
Default Fuel pump will prime but no fuel pressure
I'm trying to get my new engine started but what I'm finding is that I am getting fuel to the pump but no fuel out of the pump. It's a walbro running on hondata. It's wired up correctly because it will Prime with key on but if I try to start the engine I get nothing.
Not the pump since when I directly connect voltage to the pump it will build pressure.
Thoughts?
Old Aug 27, 2024 | 02:23 PM
ls joker's Avatar
Loved
Default Re: Fuel pump will prime but no fuel pressure
Did you verify if you have fuel squirting out at the rail during priming? Loosening the fitting after the filter, before the rail
Old Aug 27, 2024 | 02:55 PM
Mjalaly's Avatar
Yeah I pulled the an fitting off the pump when turning over the engine. No go. If I power the pump though I will get fuel. So something with the ECU
Old Aug 27, 2024 | 04:16 PM
Mjalaly's Avatar
she is trying to start. Datalogs attached incase someone can see something i cannot.
File Type: csv
Old Aug 28, 2024 | 07:48 AM
7rrivera7's Avatar
Common failure of the ECU which needs to be repaired. If you don't have anyone locally PM me.
Note: if my offer goes against the forum rules please delete my post.
Old Aug 28, 2024 | 08:05 AM
Mjalaly's Avatar
What would cause that error? What is the error?
Old Aug 28, 2024 | 08:36 AM
7rrivera7's Avatar
It's not am error. The ECU will not "boot", you will have a solid check engine light, the main relay will not engage and the fuel pump will not prime. If you leave the key in ACC for 1-5 mins, depending on how bad the delay is, usually the ECU will come to life all of a sudden, the main will engage and the fule pump will prime and the car will start. It will work fine until you shut of the car again and the ECU is not powered on again - usually overnight
Old Aug 28, 2024 | 09:05 AM
Mjalaly's Avatar
But the ECU boots else i wouldnt be able to have data in the datalog and the fuel pump does prime. The issue is that after priming the ECU is not telling the fuel pump to continue to run. So i am not following this logic
Old Aug 29, 2024 | 12:02 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It's broken. Try another "Known Good" ECU.
Old Aug 29, 2024 | 03:22 PM
Mjalaly's Avatar
found the problem was a polarity issue at the pump.
Old Aug 30, 2024 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Pump running the wrong way... that would do it. That is a MUCH cheaper fix than replacing the ECU... good find and congratulations.
Old Sep 3, 2024 | 08:42 AM
Mjalaly's Avatar
ugh still not starting. Im completely lost
svenglass
May 15, 2017 02:45 PM
95ITRJDM
Apr 10, 2011 06:09 AM
