Need Help
Old Aug 21, 2024 | 10:31 PM
ta1an's Avatar
Default Need Help
I was going to drive my car (no previous problems or signs) but after I pulled out of my parking spot, I get probably 100 feet down the road there's just slow loss of power and a loud spinning/grinding noise. The noise pretty much went away when I pushed the clutch in and it was trying to refuse going into gear. It leaked a small puddle of oil where I was sitting for a moment while waiting for my dad to help push it but ended up driving it down the road back to my house. Seems like a throughout bearing or at least something to do with the clutch/tranny. Just looking for other opinions. Happened probably 20 minutes ago. Took a video while letting off the clutch. (ignore the breathing) (manual d16y7)
Old Aug 21, 2024 | 10:37 PM
ta1an's Avatar
Default Re: Need Help
^^ also replaced clutch around 7 months ago. replaced with an exedy oem kit. (i was told after not to use exedy and just buy oem)
Old Aug 22, 2024 | 07:34 AM
theYBLEGAL's Avatar
Loved
I don't think there's any magic that can be done to fix it with the trans in the car. I think you'll have to atleast pull the trans to inspect the clutch. If the clutch looks fine, try to spin the input shaft by hand and selecting gears. If that feels like it's grinding then you'll probably need to delve into rebuilding it or replacing the trans.
It could be a failed clutch component or even a failed gear. Good luck!
Old Aug 22, 2024 | 07:41 PM
ta1an's Avatar
update- started the car around 10pm after work and sat there for about 30 seconds listening to it and the sound practically went away so I drove it probably 50 feet and sound started for a second so i threw in neutral. Its able to drive for a second and go into gear but once the sound comes, it doesnt want to go into gear. Very confusing and very hard to explain.
94hondacivicvtec
May 16, 2007 07:36 PM
ekblack9
23
Mar 14, 2007 10:26 AM
smokerz212
Mar 11, 2006 07:16 PM
Mw
Jul 1, 2004 12:18 PM
geminis2k
Jan 28, 2003 01:27 PM
