AEM Infinity 6 ECU w/Molex Tool $1000 shipped
AEM Infinity 6 ECU with Molex Crimp Tool $1000 shipped within the United States. Many Honda Engine wire harnesses available on the market. Message with any questions and for payment options.
Infinity-6
The Infinity-6 is designed for racing engines with up to 6 cylinders. It features a smaller footprint than the Infinity-8/10 (5.855” x 5.55” x 1.8”) and a single, weatherproof 80-pin connector.
Features
The Infinity-6/8h include all of the advanced features found in its larger iteration including the latest generation 200 MHz automotive processor that can process 400 MIPS. Airflow model based (VE) tuning eliminates lookup of many correction tables needed in previous generation ECUs. Flex fuel and multi-fuel capability, on-board wideband air/fuel control, map switching and knock control are included. Engine protection strategies include coolant temp, oil temp, AFR vs. MAP, intake air temp, knock or fuel pressure. Programmable drive-by-wire, variable cam timing, boost control, nitrous control and traction control are included. Data logging up to 64GB via a removable USB is standard with logging rates up to 1KHZ per channel. The Infinity-6/8h is able to communicate with 3rd party dashes and loggers and is AEMnet enabled. All maps can be password protected. Its sealed enclosure and IP67 rated communications ports are suitable for engine bay mounting.
Wiring Harnesses
AEM offers a flying lead wiring harness for the Infinity-6/8h that is 96” in length and pre wired with power, grounds, a power relay, fuse block, wideband and AEMnet. A Plug & Pin kit is also available for the Infinity-6/8h that includes an 80-pin connector with cover, 80 small pins, 1 micro relay with pins and 30 sealing plugs. Many Plug & Play adapter harnesses for popular race vehicles are currently in development and will be available in the near future.
Support
When you combine the Infinity-6/8h’s capabilities and price point with AEM’s industry leading after-purchase support system that includes free technical support, there is no question that it is the ultimate engine control solution for race teams and weekend track cars with 4-6 cylinders or crate V8s/engines up to 8 cylinder using high impedance injectors.
INFINITY EMS FEATURES:
Infinity-6
Features
Wiring Harnesses
Support
- Airflow model based (VE) tuning
- ECU Set Up Wizard simplifies start up
- Flex fuel compatible
- Multi fuel capable
- Drive by wire
- Variable valve control
- Multiple boost control strategies
- Nitrous control
- Map switching
- Internal Wideband UEGO air/fuel controller
- Dual knock sensing circuits
- Data logging up to 64GB
- Outputs to 3rd party dashes and data loggers
- Industry leading data transfer speed (up to 480Mb/sec)
- Integrated engine protection strategies
- Sealed enclosure and IP67 rated comms ports
